I've never seen that electronic cassette deck thing. What is the number "4" supposed to mean?
New to CFI and EEC lll
Cool. Looks like the same woodgrain used in the 83 Mark VI Signature, or awful close to it. I have that in my car, though I need the piece where your buttons are but from a car without digital dash.86 Lincoln Town Car (Galactica).
Yes the cooler sits between the egr and the intake i removed the cooler, plugged the coolant source, ran shorter studs to attach the egr to the intake without the cooler. The chunks of carbon that come out of that cooler had me go wtf. Best thing to do is save up about $200 and Sefi Swap your engine. Would require and 84-85 TFI Distributor, 86-89 ECM and harness. E7 heads are a decent swap but not needed for the conversion iirc. I had put E7 heads on my Blass when i did the sefi swap.
Bet timing set. Remove EGR cooler coming lines and pipe plug manifold. Unplug EGR solonoids and plug off vacume lines. Gut cats. Get rid of air pump. Dual exhaust. Run non ethanol gas. Never use over drive unless on a highway. Good vacuum lines. Good tune up. Good sensors. Should run great and get 18 to 25 mpg
