In my 89GM. a/c works kickass but the heat is kinda weak. it will get hot for a few minutes than go to room tempature and stay there. i have no idea what can be causing this.
I used to work at a cab company and i remember the mechanic there with alot of cars that had bad heat would go through the glovebox and i guess uplug/plug something in so it has good heat but when summer comes back around you have to go back and re-do it. i guess this is a cheap way around? If so im looking to check that out.
Engine temp always stays the same so i think that would rule out the thermostat. but thats all i can figure
