I am looking to find any info around a compact relay/fuse box available from JY cars. Kinda looking for a few fuses and maybe a couple of relays.
I will likely be installing something that needs a fused source and I think my p.side fuse box (I have converted to areo fuse box)is maxed out not to mention I dont want to run it all the way there when the item in question will be mounted right under the brake booster.
I have the fancy Lincoln bracket that bolts to the air boxs' rear most studs and originally holds a set of four relays. I will be likely using that bracket/modifying it to work with some fuse/relay box that is not too big.
Below you can see the 4 banger relay box behind the air box....that is the location I will be installing a new relay/fuse box if I can find one...
This is the location on my car where I would like to stab it all.identical to the Lincoln location..just behind the air box.
I like factory looking add ons as you may tell (for the most part) from my engine bay picture. Any help,suggestion and tip are appreciated.
