Motorcraft dy1145
    Motorcraft dy1145
    can this MOTORCRAFT DY1145 Temperature Sensor be used for my 87 efi 302 wagon
    I believe so (not certain), but you need to reliably connect the supplied pigtail because this sensor uses the newer Ford connector and does not directly attach to the connector on the car.
    I would just use any of the many other correct ones out there instead.
    | Junkyards
      +1, get one that fits without messing with the harness.
        RockAuto has one one closeout for $3.04, Standard TX6. I just bought one.
          I tossed one in with the order that I just received today. It's plain white box, but only so many people make these things.
          | Junkyards
            I’m using the newer Motorcraft one listed above. Splicing on the connector isn’t terribly hard. The bag includes heatshrink tubing, the crimps, connector, and sensor.
            Mine works fine.
            My Cars:
              The TX6 is what I put in The Scab a week or two ago. White box as stated.
              I had a rough idle when the engine was cold that I was able to solve with that sensor. So far so good.
              Vic
