wire question
    wire question
    the white red stripe wire whats it for
    Where is that?
      pretty sure thats the oil pressure light wire.
        drivers side comes off alternator harness.i don't have sensor in oil pan so i can lose that wire and all the old 2g wires
          In the oil pan would be the level sensor. The oil pressure sensor is on the engine above the oil filter, with a single red wire going to it (don't recall if it is solid red or red with a stripe).
            got rid of the 2g alt wires
              I assume you have an oil pressure gauge?
                you assumed right
