If you'd rather just watch a video... https://www.youtube.com/watch?v=erItV2X1XKg
I have been trying to figure out a reliable way to determine if a junkyard car has a good vacuum ATC interior temp sensor (used up to 89). As we know, there is a common failure mode where the car no longer has hot heat, because the interior temp sensor is passing vacuum when it should not be. The full heat position for the blend door servo is zero vacuum; if any comes through to it, the blend door will mix cool air and give you lackluster or totally inoperative heat in the winter, which is not a desirable condition.
If you have a hand vacuum pump and some line, you can test this part against that common failure.
Hook up the sensor and servo as they are in the car, and connect the vacuum pump to the black line going to the sensor. With the temperature set at the full heat position, pump the vacuum pump. There is continuous vacuum leakdown, which seems to be normal, but the important part is making sure the servo does not move at all even after pumping for a while (for the most accurate test, do this for a few minutes).
If the servo does not move, then the sensor is able to provide full heat. The next test would be to make sure it begins moving the blend door to somewhere cooler when the sensor is adjusted to a cooler setting. Since this will vary by the ambient temperature when you are testing the sensor, the best test would be to just set it to the coldest setting and make sure the servo can move the blend door all the way until it's fully pulled in.
Finally, make sure the sensor will release/vent the vacuum by moving it back to full heat (while it still has vacuum applied in the full cold position), and make sure it allows the servo to fully expand back to the full heat position.
This does not allow you to test the accuracy of the sensor (to numeric temperature values), but at least you will know if it functions correctly.
