Set timing, now car won't start! HELP!!!
    So I installed a new explorer/GT40 intake and got it all buttoned up. I dropped the distributor in to the exact spot from when I parked the car to do the intake swap(never cranked the engine once or moved the crank, took pictures to verify exact location) and turn the key the car won't start. Set the car to 0° before TDC and the #1 point on the distributor at the 12 o' clock position and go to fire it up and the car idles like crap for a few seconds then dies right after. All vacuum ports not used are plugged and have hose clamps, all wiring is plugged in. If I give it some throttle it stays running but runs like complete crap, sounds like it's missing. Car ran perfect before I parked it for the weekend project (it's my daily driver) and now it has some sort of ignition issue (my guess). Any help is appreciated, car is a 1990 MGM.
    Should be 10 BTDC, not 0.
    Honestly it sounds more like a fuel problem. Vacuum leak, clogged vacuum port, etc. I had a dirt dauber in the vac port on my car when I did the GT40 upper and it ran like complete shit until I realized the MAP had no vacuum.
    What are you using for the EGR spacer and throttle body? The only stuff that reliably works right is the Lightning spacer. The stock ones usually will not bore out that far and seal correctly. Throttle body is usually the Explorer one with the stock throttle lever on it.
      Thanks for the reply, I have recently put a walbro 190lph pump and new fuel filter about 5 months ago. I hope fueling isn't the problem, that would be no fun!
      The intake was cleaned spotless and free of carbon before I installed it, all unused vacuum ports plugged, the map has brand new vacuum line ran to it and double checked it wouldn't kink before I installed the intake. I have a lightning spacer and throttle body with a ported upper that's been on the car basically since right after I bought it.
      This is just mind numbing because she's been the definition of reliable and now all this. I'm going to check all the vacuum ports tomorrow just to triple check.
        Are you sure you're not 180 degrees out? Are you at TDC on the compression stroke?
          Yes I'm sure, I did the screwdriver method to make sure I was almost to the top then put it to 0° BTC and 10° BTC (some say 0° some say 10°) and it run like complete crap both ways. I even put it in 180 from #1 at 0° (just to check since it was not firing anyways) and it just wouldn't fire just a few pops.
          I'm really at a loss, I'm going to triple check all vacuum lines, connectors, and do the timing again in the morning.
            Still using the original cam?
            Correct firing order?
            1-5-4-2-6-3-7-8
            or HO stick
            1-3-7-2-6-5-4-8
            counter clockwise rotation.
            Also... I'm guessing EFI since you talk about the MAP sensor. If you're running the stock computer that expects 14# injectors... and have 14# injectors... the amount of air the explorer intake provides may require bumping up to 19# injectors. If you're running an HO stick and D9S computer... you'll definitely need 19# or maybe 21# injectors if it's lean.
              Did you remove the spout conector? You have to remove the conector to set the timeing or the computer will try and set it.
                Yes, stock EFI with LoPo cam. I know its running rich as of now so 19lb. injectors wouldn't help and they dont play nice with the stock ECU anyways.
                I reset the timing (again, FML) 10° BTC, #1 point at 12 o'clock, spout connector out, and still runs like complete trash.
                I checked all vacuum lines and ports to make sure they're tight and there are none that I forgot.
                It seems when I unplug the MAP sensor it idles a bit better but still runs like complete trash, rush as can be and still missing but just a bit smoother is all ive noticed.
                  IAC? TFI? I don't know if it would throw codes that fast, but have you checked KOEO & looked for stored codes since trying to set timing?
                    There's no check engine light on which is weird, I know that works because when my o2 sensor was bad it was on but now with thus problem is it not on at all other than just when the key is first turned.
                    IAC and TFI were both working 2 days ago before I did the intake swap so ide assume they're still good. I know, bad to assume they're good but I would hope they didn't go bad in 2 days after all the time working.
                    I am a bit lacking on how to check codes through the OBD-1 port and no one I know has a scanner that fits the Ford OBD-1 port.
                    I plugged the MAP back in this morning, set the timing (AGAIN! I hate life as of now lol), and it is running decent. Idles alright, seems about 200rpm lower than usual, and it sputters and misses when I took it around the block to see if it was running ok. Assuming I'll have to fine tune the timing now or could it be something else now? This is a real PITA for something I've done quite a few times and never had it turn out like this.
                      At least the timing is closer now. It should get better if you rotate the distributor body in one direction or the other.
                      If rotating the distributor body clockwise helps (advancing the timing), you may benefit from pulling the distributor and rotating the shaft one tooth counterclockwise. If rotating the distributor body counterclockwise helps, pull distributor and go clockwise with the shaft. Keep going until you find the happy place...
                      I recall someone several years ago that put a GT40 intake on an otherwise stock lopo and it was never really a happy engine. Username was N A I think.
                        I think that's what I'm going to end up doing once I get a timing light later to dial it in 100% to where it runs as good as it did before(if possible). Hopefully that's all the problem is, I'll keep my fingers crossed.
                        As of now, the car has the explorer/GT40 intake, Lightning EGR spacer and throttle body, Mustang shorty headers, modified Summit H-Pipe, and Upgraded ignition (FRPP wires, Motorcraft plus, MSD cap and rotor, Summit coil). I have a A9P ECU, HO cam, and fresh 19lb injectors to go in but only have GTP heads in the junkyard, no GT40's and people want 100 bucks for some stock E7 which I will never pay.
                        I will return to report if I fixed it or it got worse. I'll pray to the car gods that it doesn't get any worse haha.
                        Thanks everyone for advice, any other info on what it could for sure be is greatly appreciated
                          The only other think I can think of is bad MAP sensor since it runs better. Might try with the stock 14# injectors.
                            I'm most likely gonna try a new one later as well since they're not that much and i can return it if it doesn't help or fix the problem, also going to try and dial in the timing better than what its at now since it still runs like crap.
                            It still has the stock 14# injectors, the 19#'s are wrapped up until I get time and a bit more dollars to do the HO swap.
                              Are you using a timing light? If not, get one and set it to spec just to rule it out.
