The rear defrost on my '86 CV is on a constant hot circuit. The switch is broken too. As such, we had to bungee it in the "OFF" position to keep it from draining the battery overnight; been like this for years. To remedy this, I am thinking of finding the hot wire (whatever color that is) and splicing it into an ignition source. That way at least I won't have to worry about the defrost being on all night. At some point, I will get another switch (from a newer Panther) and make that work. My question(s): is this the proper way of doing this?
Rear Defrost
replace the switch. It actually does have a sort-of key on only function to it when working. If you shut the key off, it releases an internal latch so the switch opens. BTDT on my own car, which is why I know that a good switch shuts the defrost off when you turn the car off.
If you want a redundant cutoff, use a relay to get it done. Drive the relay off a key-on source, use the relay to break the power feed into the defrost switch. Don't run the thing through the ignition switch, it pulls more current than the switch is able to deal with.86 Lincoln Town Car (Galactica).
yeah, that can happen too. all things considered I'd rather it fail off than fail on. Its less annoying to hold the switch than it is to jump a car when its parked the wrong way in a driveway and cold outside.86 Lincoln Town Car (Galactica).
