I am getting a AMP light at idle and only 12volts at the battery (Checked with meter) no matter what engine RPMs. I have had a power pulse in the dash lights and alt noise on the speakers since I bought it but I just assumed it was a iffy ground in the dash and had not looked into it. NOW, I have a 3G I pulled from a Taurus and the mega fuse with holder and 0Ga. wire for my Bronco but it has not been installed yet. The guides say that the mustang (Small Frame) is a direct fit for my 89 GM but that the Taurus is the large frame and fitment is theoretical. Has anyone used the larger Frame? Otherwise I might have to hit the yard Saturday to find a Alt but I have my doubts I will find one.
I think my 60Amp alt is failing, question about 3G
if it's from a 3.0L taurus... you're fine. If it's from a 3.8L taurus... you will need the large frame bracket (the curved top mount bracket).
To complicate matters there are different case sizes but what matters most is the overall dimension shown by Kishy. Some also require clocking, which is changing the front case to back case positioning. Taurus may not.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostSome also require clocking, which is changing the front case to back case positioning. Taurus may not.
It's usable (I have 3 that way) but looks a little neater if you take it apart and re-clock it.
If you pulled the alternator off of a non-Duratec (non-DOHC) 3.0 V6 Taurus/Sable, you're fine. You'll just find the voltage regulator plug will be down on the right side of the alternator when mounted instead of on the top.
The V6 Mustang one from '94-'00 also drops right in. That one will have the voltage regulator at the top like the 2G alternator.
My Cars:
most auto parts stores will check them free of charge.86 Lincoln Town Car (Galactica).
Factory fuse link. Its not melted at least.86 Lincoln Town Car (Galactica).
