Whilst removing the brake booster, I discovered a plastic collar at the base of the steering column (next to the brake pedal) that had one line and one open port next to it. I did some searching and discovered a vacuum line with a screw jammed into it. Traced it back through the firewall and into the vacuum tree. Not sure what this line does, but I took the screw out and reconnected it to the open port on the plastic collar. Does any of you know what this plastic collar is and what purpose it serves. Thank You
I will upload a picture shortly....
