I currently have no vehicles with working A/C, and I've seen some discussion here lately that makes me think we have A/C-knowledgeable folks here.
The Town Car A/C did work up to perhaps 6 months ago, and then went to the rapid clutch cycling symptom, which I believe indicates low refrigerant = a leak somewhere. When that happened, I unplugged the clutch to prevent it running unnecessarily when using A/C vent modes. The system is still R12. I'd like to look at my options to repair and fill it with R134A, but I lack certain tools and knowledge needed to do the full job.
What I'd like to do is:
I understand our cars have FS-6 compressors which are considered pretty reliable and adequate for R134A conversion, correct? I also understand they aren't prone to "black death"?
I understand that since not all components of the system are being replaced, some of the old oil will remain, so I need to pay attention to the type of oil used with the new refrigerant to avoid reactions between the old and new oils. What I have gathered so far is that the existing system uses a mineral oil, a completely new R134A system uses PAG-42 oil, but because some mineral oil will remain, I should use ester oil. Can someone please confirm this?
Also, I do tend to like doing stuff myself, so I would love to have the knowledge to do this myself. Is it possible to pull off a successful vacuum and charge at home, and if so, what tools do I need? I figure 134A conversion fittings (have them), manifold gauge set (don't have it), vacuum pump (don't have one sufficient for this use), and of course the R134A itself. Anything I'm overlooking?
Is it possible that I could do the leak testing myself? What would be involved with doing that?
The evaporator is of course a pain to access, so I'd rather not need to change it. How likely is it that it would need to be replaced? Is leakage the only true failure they can have?
The condenser is not available new for MY 85 and down Panthers...but it is for 86 and up. Same questions as for the evaporator, should I expect to need to replace it? And what makes the 86+ different?
Not in any sort of rush with this, though I am quite uncomfortable without it, I don't want to rush to a solution and find out later I missed something.
- Have a shop empty the R12, so I can disassemble and work on it without venting it (don't care about legality, R12 is legitimately damaging to the environment and I don't want to vent it on that basis)
- Have a shop leak-test it and indicate to me where the trouble spots are.
- If shop recommends it, have them flush the system.
- Once leak test information is known, I'll take the car home, disassemble, replace O-rings, hoses, orifice tube etc
- Bring new drier with me, install it at the shop or just have them do it (to minimize time the drier spends unsealed)
- Have shop vacuum and fill system with R134A and lubricant as appropriate.
