Anti Freeze Smell
    Anti Freeze Smell
    Ok all,
    Just changed my water pump, timing cover and Timing chain, do to leaks, also changed all hoses in front of motor.
    Now i notice an anti freeze smell when i turn the heat on the first few seconds its on, then it goes away.
    What could be causing this? Or could it be just pulling in the remains of the coolant smell that leaked all over?
    I dont see any wet marks on the ground from leaks, nor is my carpet wet on the pass side floor , like a heater core leak.
    If you put new heater hoses on, check that they are not having a little drip at the heater core. Buggers are hard to get tight.
      Didn't change those
      Just the radiator , thermostat bypass and the one small curved heater hose from the water pump that feeds the heater core
      But the ones at the firewall weren't touched
        still worth making sure they aren't leaking, same with the rest of the connections. Also not impossible the heater core is bad if the cooling system is making pressure now and was not before.
          Gadget
          Thanks
          Didn't think about the pressure now
          Since the leak is gone and a new pump
          Is in.
          Time for some dye and a black light
            heater core, you fixed all the lower pressure leaks. one of my friends has a theory on this, suprized he don't have a flow chart lol.
            what psi is your radiator cap?
              heh, the Dancy leak pressure theorum?
