Can anyone help me find this relay? The Haynes manual doesn't help at all. The interior lights keep getting stuck on. Head light switch has issues too, dip beam won't work, only mains. Wondering if the relay is inside the switch and that's what's causing the problem. I jiggled the switch yesterday and everything started working properly again. Can you buy new head light switches or do I need to go to the pick-a-part?
Thanks in advance
Thanks in advance
