Update:
Ya dudes were all right about the TBL, Motorcrap replacement was leaking. System itself held 22 -whatever abbreviation used for vacuum- for 3 minutes. Back started to hurt so I had to move, otherwise I would've tested it longer. Tested it right at lines going to TBL, the black line. Was going to test soup can and system from soup can's line but couldn't get line off. I think it's safe to say that trash isn't trash since it is all linked together and held vacuum. On a side note, I couldn't find vacuum distribution tree either, hidden by lots of garbage or I'm just not good at finding things. Well, I did discover my throttlebody is leaking coolant at the gasket so that's gotta get refurbed..
You dudes aren't going to like the solution though- I cobbled another TBL together from the old body with the new TBL's guts, that one seemed to hold vacuum whereas the "new" one didn't.
