Vic posted in the second post an electronic corrector. It should work on your car.
Speedo Re-calibration gears...
if 3.55s were added later... the original was probably 2.73 or 3.08 I'm guessing... so the output shaft is 8 tooth. You'll need a 21 tooth driven speedo gear to get the speedo correct with 3.55s and stock diameter tires.
Originally posted by Tiggie View PostVic posted in the second post an electronic corrector. It should work on your car.
Originally posted by sly View Postif 3.55s were added later... the original was probably 2.73 or 3.08 I'm guessing... so the output shaft is 8 tooth. You'll need a 21 tooth driven speedo gear to get the speedo correct with 3.55s and stock diameter tires.
Thanks again everyone.1990 Crown Vic - Lowered, E303 cammed, Short tube headers, H-pipe and Thursh welded mufflers dumped....MANY UPDATES COMING
1999 Expedition EB mildy lifted on 33" Toyo's
2012 4Runner Trail, 33" Duratracs, KDSS,lifted and louder.
Originally posted by Vwright14 View PostOops totally missed that...and thats actually the same one i used on my stangs
ok cool ill use that site Gadget posted and see if a i can get a correct tooth guess-timate
It works great for my '91 MGM.
Kinda weird how the Panthers went electronic speedo in '90 but the Mustangs didn't go electronic until '94.
Even an '80s digidash car would work with that unit.Vic
Yeah it's crazy how ford used technology....oh yeah sure mass air in stangs in 87-88...oh crown vic, nahh your fine....trucks..ha get bent..buuuut electronic speedo ok ok fine....now mustang stop complaining you got mass air and better heads!....trucks we gave you a 351w lightning now just be happy!
Sent while like doing stuff and what not.1990 Crown Vic - Lowered, E303 cammed, Short tube headers, H-pipe and Thursh welded mufflers dumped....MANY UPDATES COMING
