Can a front door with the vent window be swapped over to a door without the vent?
Doors interchange
Yes. You can also install the vent window and appropriate glass into a non-vent window door if you want to go that route. Door itself is identical, only the glass is different.86 Lincoln Town Car (Galactica).
Let's go one step farther - how about a power to manual window swap?1990 Country Squire - under restoration
probably possible but why would you want to?86 Lincoln Town Car (Galactica).
