So I noticed when I was driving what sounds like a vacuum leak but it's coming from the inside underneath the steering wheel. So I went under and didn't see a crack in the vacuum hose however I did see this fitting possibly cracked (see pic)
It only hisses while in drive and doesn't immediately start I have to drive like .25 miles. The hiss will go away when I accelerate. Any ideas on what this might be? It's hard to figure it out because it only happens whole in drive. If I shift into neutral or park the noise goes away.
