Alright, I guess I'll start posting info on the swap. I never organized anything into an actual write up, and don't have access to my pictures and diagrams that are currently at home so this first post will be just general details.
The swap I did was EATC from a 1997 Lincoln Town into my 1991 Mercury Grand Marquis GS which had ATC stock. There are some bugs that I haven't worked out though, I'll get into that later. I haven't even bothered to do any troubleshooting since I have a workaround and no time to actually fix it.
90/91 requires very little physical modification to the dash. Make the rectangular hole slightly larger (I never actually took any measurements) on top and the sides, widen the holes in the dash for the locating tabs on the back of the new unit's face/mounting plate, and you may need to enlarge a couple of the screw slots inward a hair on the new unit's face/mounting plate.
For wiring:
Grab a sunload sensor and run wires to the back of the new control unit. (I don't remember, but this might be only if you are using a Lincoln unit.)
Newer style BDA bolts into place of the stock 90/91 BDA, then add the extra wires that the new one requires and run them to the back of the new control unit.
After that (you know, putting your whole dash back in place) it's all wiring of at the back of the unit, and swapping the vacuum lines into the new connector that goes on the back of the new unit.
No need for the silly TBL with a newer unit either.
On an '89 or older box I'm not sure how much more work would be involved or if the swap would be worth the extra work.
The system has been in place for about a year now. My car never had Working AC since I've owned it, compressor seized, but I'm certain I have the AC portion all wired in correctly. IIRC the wire colors and functions were all the same between the two systems for AC related stuff.
The only bug I have is the unit will go into a state where it no longer controls the temperature adjustment when I try to adjust it. The display shows that I am changing temperature but actual temperature at the vents does not change. If I disconnect the battery on my car long enough to let everything reset the unit works without any issues until some time (days, weeks, months, I don't know) later when it goes back into this state.
I have no desire to fix it, this is very low on my list of priorities if it even makes the list.
Even when it is acting up, as described above, in self test mode I get 2 codes, one for not having engine coolant temperature input and one for not having vehicle speed input. From the schematic I had, I believe both of these inputs come form the ECM. The two wires on the back of the unit that would talk to the ECM are not connected to anything. This may or may not be the cause of my bug but, like I said, I have no desire to fix it anytime soon.
I'll post more details, like schematics and pictures and stuff when I get a chance.
For wiring:
