I’ve been dealing with a coolant leak ever since I did the HO upgrade. It was leaking in between the joint nut in the heater hose pipe. After exhausting every known fix I could try, I went a built a new heater hose setup. I couldn’t just replace the pipe with new heater hoses, due to the coolant temperature sensor.
I took an old pipe from a Mustang intake. I chopped it up and reassembled with JB weld (real welding may be better). I made rings from an old hanger. I placed them on the pipe to give the hose something to hold on too. I JB Welded them in place and ground down the outer rings to make it easier for the hose to slide onto the pipe. I painted it with high temp engine paint. I installed a heater hose fitting into the manifold and used an old “S” heater hose from the back of the engine (only 2 months old) and made a 90 degree angle hose for the pipe. Then finished the rest of the hosing with 3/4 inch heater hose, one to the pipe and one to the water pump. No more leaks!
Not sure what others have done to fix this problem, so here’s my remedy.
![Click image for larger version
