Ac condensers
    Ac condensers
    noticed THE STOCK ONE IN MY 87 HAS 3/8" tubing and aftermarket ones seem to be 1/4" tubing. Anyone use one of these and did AC work better or worse. Look like they might flow a bit different also. Guessing it might not cool as well. oil fill and charge could be less also
    I'd actually like to consider fitting a multi-flow unit out of a later model in. They are a lot more efficient than the old tube and fin setup we got from the factory. I know thats supposed to do amazing things for the Fox AC performance. Our cars convert over pretty decent though, so it may not be as much of an improvement.
      Also just noticed the OEM one air flows around each tube front and rear tubes. Aftermarket one the tubes in the front block air from the rear tubes.
