Cornering lights
    Cornering lights
    The left corner light stays on. Does anyone know where the relay is located for this light?
    I have a 1984 Grand Marquis.
    Under the dashboard, directly under the column. You'll see two round things that look like blinker units with tabs on them mounted to a bolt on the column. Those are the cornering lamp relays.
      Do you know where they can be purchased?
        Can be pilfered/purchased from a junkyard near you! I have some spares...
          I've never shopped for new ones. They may be available. Honestly don't know.
            We've already gone through this some time ago. Relays are not available. Junkyard is your only option.
            That said, has anybody tried a home-made delay relay? I got a simple schematic around here somewhere that might work as a replacement.
            Alex.
              I've actually been meaning to try swapping in a Mark VII MF switch to eliminate the relays entirely. They have a dedicated contact for the ditch lights that don't rely on that wanky timer relay thing that the stock rig uses.
