Window motors
    Window motors
    Window motor in the wagons passenger door finally locked up in the down position. It was the discs about all ground up. Here is the issue cleaned the gears up and purchased replacement discs. Issue is they must be a bit larger in dia than OEM ones as I couldnt assemble them in the rig gear and drop the driven gear in. Finally did a bit of dremel work on the ring gear pockets were the discs go and got them to fit.
    Last time I did this there was no assembly issues screwed by overseas tolerances again.
