So about three or four weeks ago the airbag light starts coming on and occasionally flashes on my 1990 GM. Is this a known issue or easy fix or would it be best to disable the airbag system? I did find out that NC won't fail the car for the light being on (GOOD!).
Airbag light is on and sometimes blinks
95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
96 Buick Roadmaster Limited Wagon, mostly stock
77 Ford F150, 400M auto, longbed
98 Suburban LS 5.7L Vortec, stock
90 Grand Marquis, stockTags: None
Count the blinks, what code is it throwing?
2 - All Primary Crash Sensors Disconnected.
3 - Air Bag Deployment Circuit - Low Battery Voltage or Low Backup Power Supply Voltage
4 - Safing Sensor - Diagnostic Circuit Open or Low Primary Crash Sensor Resistance
5 - Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
6 - Driver-Side Air Bag Circuit - Open or High Resistance
7 - Passenger-Side Air Bag Circuit - Open or High Resistance
8 - Primary Crash Sensor - Not Mounted to Vehicle Properly
9 - Primary Crash Sensor Circuit - Open or High Resistance
10 - Diagnostic Monitor Internal Thermal Fuse - Open Due to Intermittent Short to Ground
Also, note that you can't just pull the bulb to get rid of that annoying light. The Airbag module checks resistance across the Airbag light circuit, and removing the bulb makes it very angry.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
OK, it is blinking 9 times, so code #9.95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
check the crash sensor... that code is usually a bad mount or the wire disconnected. It grounds through the rad support, so that interface needs to be decently clean. I have no clue where the thing is mounted, though I would guess top center around the hood latch (look for a metal box with one wire going to it).
Thanks Sly. Will check right now. Are there two or just one?95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
So you all are thinking there's some issue with non-conductivity between either the sensor and ground, or the sensor lead to the airbag module? If I go jiggling the sensors around (re-establishing a ground), should I first disconnect the battery, or is the module smart enough to know the car is not moving and not to blow the damn airbag?95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
Usually its the mounting bolts are crusty and its not making a proper ground, or the connector is dirty and not making good connection. Could be any of the sensors, so clean all of them. Unhook the battery first, just in case it wishes to do something stupid. It normally takes both a primary (the 3 up front) and the secondary "safing" sensor to "make" before it blows the bomb though. The safing sensor is probably in one of the kick panels, though I'm not positive which one. The Mark VII used the same system, and it lives in the driver's side on them.86 Lincoln Town Car (Galactica).
I thought the 90 model has just one... I've never seen that setup, so I dunno. Listen to the others on that. And yeah... Thain probably knows more about it than I do.
well, I assume its got the 4. Mark VII's in 90-91 had that same control unit and they had 3 along the rad support plus the one in the kick panel. Might only be 2, the primary and the safing. I've honestly never looked close at that system in boxes.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postwell, I assume its got the 4. Mark VII's in 90-91 had that same control unit and they had 3 along the rad support plus the one in the kick panel. Might only be 2, the primary and the safing. I've honestly never looked close at that system in boxes.
I assume there weren't any radical changes to the system between 90 and 91.Vic
nah... the major changes happened in 92... mainly with the 2-digit codes and diag module (controller). Think it still had the same crash sensors though if its' 3 up front and the safing.
Vic
I unhooked the front one next to radiator and reinstalled. No change. Can these things just go bad?95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
I meant that I uninstalled and sanded the bolts and then reinstalled. Are these 'boxes' still available from Ford? I do have the three (one each fender and one under hood latch). The ones on fender aren't easy to get to. Wish that error code narrowed down problem.95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
