The last few days I have noticed the following issues with the A/C:
1) It is Auto Fan capable and even on a set speed, the fan speed raises and lowers.
2) The Receiver/Dryer is barely cool and not "frosty" as it usually is.
I was thinking the first issue was the fan switch, which I replaced. The connector, that many times is shorted "appears" ok. Only changed the switch but not the connector. Same problem so it didn't help. Could it be the Blower Resister?
I checked the low pressure side and it is in the 40's. Don't have a high pressure gauge so I am limited. Also didn't take a reading of the inside temps. They feel "cool" but not "cold". Could there be vacuum issues? Perhaps the control unit has issues? Just throwing it out there to get some ideas.
