'87 GM A/C Issues
    they do make small rubber hoses that small. Honestly I'd leave it sealed. What that does is open the recirc door so that air can't push inside while you're driving along in the cold weather until the engine is warm enough to make heat. I don't expect you get arctic conditions down there in Florida often enough for this to matter. With no heater core, it doesn't make a bit of difference.
      Probably going to do just that. As long as the A/C works well I'm a "happy camper". Thanks for pointing it all out!!
        Just as an update and to say thanks for all those that took the time to help - had the car out yesterday and with the two vacuum lines going to the TBL capped, the A/C was PERFECT. As long as it stays that way, JOB DONE!!
          The only thing that movie was good for is a source of mockery. And the occasional air conditioning appropriate meme.
