Anyone know where I can get OEM yellow bulb grease?
    Hey all,
    I've had my car back from the shop for about a week now but am having problems with the parking lamp, doesn't always stay lit. The socket was paritally ripped apart during the wreck so I suspect a wire is only attached by a few strands of copper. I'm going to take it apart to fix it but I want to buy more of that yellow grease all of the OEMs use (the socket in question is loaded with the stuff) to put back in when I'm done. Do any of you know what it's called or where you can buy it? Small things kill me, I'm happy the shop didn't lop off that connector in the first place to replace it and if I don't put that yellow crap back in I won't be able to sleep at night lol.
    I found this:
    MOLYKOTEŽ G-5008, but it seems you can't buy it anywhere as all I'm finding are MSDS's.
    Thanks for reading more of my babble!
    dielectric grease. parts store or hardware store.
    Originally posted by SVT98t
      I prefer the clear-ish dielectric grease... but then I'm not having my cars judged for perfect original quality.
        I've got a tube of the clear crap but its just one of those things. If I can keep it original I'll do my best but if not then I'm at the mercy of whatever suppliers are making alternatives. Bobcat, the parts stores by you have the yellow stuff?
          I also prefer the clear stuff since the yellow stuff tends to crust up and cause issues here in the south. The clear tends to remain a gel longer
            Ellsworth adhesives
            tel: +1 877 351 4811
            35400 mound road
            sterling hts michigan 48310
            1986 Mercury Grand Marquis "5.0" (160,000)
            2011 Ford Crown Victoria "4.6" (54,000)
            2015 Jeep Wrangler JK Willys "3.6" (48,000)
              +1 on the clear stuff. That yellow shit turns to glue and you can't get the damn bulbs out. I've destroyed some number of lamps on my own car when an original failed and that yellow shit just would not let go.
                So the clear stuff is essentially the same deal minus the turn to glue part?
                  Pretty much
                    +1 on the clear stuff. It maintains its consistency much better than whatever the other stuff is.
                      Turns out the bulb was bad, wasn't anything wrong the wires.
