So this has been going on ever since I upgraded to the 3G. Squeal on startup. It goes away but is annoying as hell. Belt is new and tight. In fact I worry that it is too tight. Alternator practically new. This has gotta be one of the most frustrating things. Should be something simple but I can't figure it out.
Persistent alternator squeal after 3G upgrade
95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
96 Buick Roadmaster Limited Wagon, mostly stock
77 Ford F150, 400M auto, longbed
98 Suburban LS 5.7L Vortec, stock
90 Grand Marquis, stockTags: None
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Nice place to be from. Know exactly where Lawrenceburg is. Used to live in lexington. I knew a guy there named Bob Adkinson.95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
The belt routing on these is a bit sketchy. Seems you really have to reef on that tensioner to get the belts tight enough to not scream. Mine always end up tighter than I think is correct to be quiet at any rate.86 Lincoln Town Car (Galactica).
I get a squeal when I first start the Box with it's 3G. Belt is tight, so meh.1990 MGM: $50 E7 heads, HO cam, Holley SysteMAX lower intake, HO upper intake with an Explorer TB. LSC ECM. Lincoln logs into stock dual exhaust. K&N drop in air filter. Wide ratio AOD, 2400 converter with a 3.08 one tire fire out back. Car is less slow now. Then there's the '92 Beater. Dual 2.25" exhaust with shiny tips. Rumbles nice. Super slow. Burns oil too.
mine (the 88 mgm) does that on startup too, but it's the power steering pump pulley slipping. meh.
Originally posted by sly View Postmine (the 88 mgm) does that on startup too, but it's the power steering pump pulley slipping. meh.
Originally posted by alchemist View PostNice place to be from. Know exactly where Lawrenceburg is. Used to live in lexington. I knew a guy there named Bob Adkinson.
How long ago were you in lex?Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Just over thirty years. Went to UK, graduated and moved to NC. But I'll be back. Wife is from Campbellsville and we'll likely retire there.95 DGM Impala SS, 383, LT4 cnc heads, LT4 matched intake, Holley 58 mm t/body, GM 846 cam, GMPP 1.5 rr's, F-body MAF, BH OBD I PCM, LT4 knock module, K&N cold air, Edelbrock headers, Flowmaster exhaust, BBHP #73 6-speed, 4:10 gear, sloted and drilled rotors, Z28 cluster
