Ok, ya all put on yer thinking caps for this one!!!
    Box cars from 1980-1986 take the following wiper motor:E6AZ-17508-A
    From 1987 to 1993 the following motor was used E7AZ-17508-A
    Then in 1993 Ford updated the number but the motor was the same: F5AZ-17508-B
    So are you all as F-ing confused as I am?
    Oh, F4PZ-14A411-B kit is to be used to wire the new motor where the old pre 1987 motor was used.
      David had no reason to use a wire kit as his car is a 1987 and has the new motor and wire assy.
      I think David converted his, but its a 1 plug vs 2 plug motor. Mine is a 2 plug, one into the motor and one into the gearbox for the parking switch. The later ones have just a single plug that has wiring for both. I think the adapter harness basically has the single motor plug on one end, and the 2 plugs on the other. I know I've seen that harness before, but I expect more people just lop the connectors off and re-wire it. I believe it changed sometime early in the 1987 production but maybe it was full year. 87 was a funny short run year anyway, and '86 has a lot of strange one-year parts and crossover parts that don't list correctly.
        Here you go folks!!
        http://www.performanceprobe.com/inde...ticle=95-08-02
