The boat is running, sorta. Still can't idle consistently and has a leaky bowl transfer tubes, anyway
The alternator light is steadily on. There's at least some charging going on, as when I let the engine almost die, the lights dim, and they get brighter as I rev up again. The smaller of the two positive wires (orange and black, going to the voltage regulator) has some cracking around the boot but no broken stands I can see. Otherwise the wiring seems good. As I try to clean up the wiring after all the changes (none to the alternator/regulator wiring) I have put the wire from the alternator to the starter solenoid post directly on the battery terminal. Could this change anything? Anywhere else I should look at? I do have access to a good voltmeter, test light, etc. but getting a consistent idle RPM is going to be difficult now. Also, voltage regulator (external) is 3 years/5K old.
