So, this is my first car, so I don't have any pre-existing standard by which to judge how some things are working. One of these things is the climate control. I thought it was working properly, but upon further investigation, I am an idiot.
The problem is when I set the switch to defrost, it mostly blows air through the front vents and only kinda-sorta onto the windshield. The rear defrost works better, which should have told me it wasn't working right in the first place, but whatever. Hindsight is 20/20 and whatnot.
There are a few other odd things it does that might be related. When I turn on the power, there's a plastic-sounding squeak behind the glovebox. When I then start the car, there's a much louder and longer squeak which seems to sound like something opening. When I turn the car off, it makes a series of squeaks that clearly sounds like something large and plastic closing.
This has to be what's causing it, but I have absolutely no idea what is even behind the glovebox, let alone what there could be making such WEIRD noises.
Whatever it is, I get the impression it's going to be expensive to fix. What can you guys tell me?
