Hello,
I'm still trying to track down my misfire in the 91 GM. The misfire is continuous, except when using very light throttle. If I turn the ac on or the headlights the misfire is a lot worse. Any clue to the misfire? All of vacuum hoses have been replaced, the intake has been gasket sealed down, ALL sensors except the DS O2 sensor has been replaced with new. The DS O2 sensor wires are not connected to anything. This has been a long on going project trying to track down the misfire the last few months. Plugs, fuel injectors, dizzy cap, dis rotor, plug wires replaced new. The coil is 6 months old, a MSD Flame thrower model. I'm going to replace the coil again today, and wait for the code scanner to arrive next week to see what it says. The cheap code reader I have does not read anything anymore.
Could the valve train cause this? I hear no noise or blow oil/smoke.
Could any of the relay switches cause the misfire? I have replaced the fuel pump relay a few times when it would idle like crap and that cleared it up.
I did a FPR test and the numbers were within spec.
Thank you,
Mike
Thank you,
Mike
