of course not the end to the pcv,
the other end to the ?
thank you,
mike
This might help a little. PCV hose is circled in red.
Thank you John and HiFi,
I found it. It had a short hose connected and plugged off with a bolt, hiding the line. A bit of oil came out from the manifold line. I put the screen and PCV valve in too.
For the newbies at changing the PCV valve.
Its works best to not look for the PCV valve, its hidden under hoses and wires.
From the passenger side, right behind the intake, run your left hand down along the rear firewall, then reach back toward the intake and you will feel the PCV valve.
Thank you again JohnUnit and HiFiMerc
Mike
