Was under the hood for a change, saw something I had never seen.......turns out it is a vapor canister purge valve solenoid.
Do I need it, how do I know it works?
Thanks!
If its not giving you problems, assume that it works and leave it alone. If the tank does not hiss vapors, suck air in, or generally smell like gas, its probably fine.
I did cut back the vac hose, because it was split at the point where is pushes onto the nipple of the valve. You know I am thankful most parts have FoMoCo part numbers on then, I can do a web search and find out what things are.
it allows the intake to take stored vapors from the gas tank out of the charcoal canister under the battery (accessible from below). This prevents gas vapors from being vented into the atmosphere and making everything in the car smell like gas.
