Raintracker
    Raintracker
    Dear Panthers,
    Brandon, who some of you met at Scotfest, is installing a rain sensing windshield wiper control and has a question.
    alright guys, i have found the wiring for the windshield wipers, and have found the power wires, but i need to know which wires control each wiper speed. i have two diagrams for the unit, one is hot side switching and the other is ground side switching...i believe i need the hot side??... i may be wrong though.
    For which vehicle are we talking here? Your 89 CP ?
      Yep. 89 cp
        Rainsense wipers in a box? Epic.
        I had then on my 09 Genesis, they are quite a nice feature.
        Past Panthers
          ok, finally out in the shop and remembered to dig out my EVTM.
          Looks like the wiper motor is common positive. The high and low speed switch changes which connection the ground feeds to. The 86 book tells me the orange one is low speed, and the white one is high speed. Common positive should be yellow/red. The dark green and red wires are related to the parking cam setup.
          The 89 motor I know has different plugs than an 86. Possible your wire colors are not the same. Hopefully someone with an 89 manual can confirm. I also know its possible to put a later model motor in the earlier cars with some adapter plug harness, so I would presume that means the switching arrangement is the same.
          **edit** the 91 Mark VII book agrees on the wire colors, but that uses a rather different control rig than the panthers use.
            Thanks. See you at SF.
            Donald
              I can check through my '89 EVTM if you still need it.
                check it anyway just to make sure.
                  Can't find my books, darn.
                    I'll do that once I'm off from work
ID:	1275904 I also have a pdf version I can send. From '89 Town Car EVTM
                        yup... the consensus is low side control, high side common power.
                          ok after looking over the diagram, i have some of the same colored wires but not all...i have 8 wires...org..blu/wh..blu/pk..blk/wh..grn..brn/wh..blk..wh....this is what im looking at..Click image for larger version
ID:	1275911 Click image for larger version
ID:	1275912 Click image for larger version
ID:	1275913 Click image for larger version
ID:	1275914 Click image for larger version
ID:	1275915 the last one is the diagram for the unit.
                            you may have to ring out which wires go to the motor and to the washer pump as the wiring diagram has two bk/wh marked. I would ring out all the wires to see where which one goes and verify which is which. Ford (along with everyone else) was notorious for typos and wrong markings in the manuals.
                            If they are actually correct though... here's what I have
                            wires...
                            org.. Wiper on/off
                            blu/wh.. Interval adjust
                            blu/pk.. ??? maybe blu/org - Motor low
                            blk/wh.. WASHER PUMP or Park control
                            grn.. BATT+
                            brn/wh.. ???
                            blk.. Gound
                            wh.. Motor high
                              Do you have the diagram for ground side switching? The posted one is for hot side switching, which is not what your car runs.
                              Also I'm assuming you are looking at the plug under the dash that connects to the wiper governer?
                              WHat would really help is a scan of the 89 Vic/GM EVTM. Towncars can be different enough to confuse the issue.
