doing a 4g alt soon........they dont have a stator plug.....what do i do with the stator wire on the cars harness?
4g conversion
4g conversion
Tags: None
dos'nt the stator plug just go to the voltage regulator. If you use the proper voltage regulator for the alt. you prob wont have to worry about it. If the alt is internally regulated (which im betting it is) then the stator wire on the car would go to the old voltage regulator, so now it would go nowhere.http://secondhandracing.com/Home.aspx
You know what? I do remember when we were playing with the Vic's harness that stator wire does go straight to the VR plug on the side. Deuce is probably right, its just internally connected.86 Lincoln Town Car (Galactica).
