ac mockup
    ac mockup
    got my ac parts all cleaned up. just doing some final touches
    I swear, given the restoration/preservation techniques you use, when some archeologist in the 5th millennium digs up the only remaining example of a ford automobile it will be your wagon.
      thanks for your pic helped me out alot.
        no kidding... and my 88 will be beat to hell and back and probably finally rusting from the inside out since it's oil undercoated already.
          put in evaporator/accumulator/drier and heaterbox assembly and did blower relay
            very nice.
              Does it spit ice cubes out of the dash yet?
                Cool - a rolling bar!!
                  got brackets and compressor on.
                    does anyone have a part number for the serpentine belt that works for smog pump elimination and under drive pulley?
                      I believe it is discussed in this thread.
                      Everything to do with interior and body electrical including headlights and tail lights. CFI specific discussions and AC/heating systems.
                        and under drive... try the 560k6 first. It's too tight with stock pulleys to get over the tensioner without removing the set bolt from the back and should probably be perfect for underdrive pulleys.
                          put heat sheild on plenum box and put some on frame under the drain hole of evapor to protect it from water dripping on it
                            i drained my ac compressors oil and every ac part is new on my wagon. the shop manual says 13 fluid ounces dose it take that much with a dry system
                              Are you asking is 13oz. the amount for the whole system or just the compressor?
                              Don't have the answer, just trying to make sure I understand the question.
