Right turn signal issue
    Okay so I got my TownCar at my buddies place for now since we have no room at my house for it right now, and I went to take it in to see what it needed for a safety and I noticed my right blinker light on the dash was on, and whenever I went to turn the right signals on all they would do is turn on and not blink at all. Why? I'm fairly new to Panthers, especially older boxes so any info would be nice. Thanks
    2011 Ford Ranger Sport 4.0 2wd - Magnaflow Axleback exhaust, K&N 63 Series CAI, DiabloSport 87 Octane tune, LEDs, 3000K LED projector fogs, 5000K Mini H1 projectors - Daily
    1967 Ford Galaxie 500 Sedan "C-Code" - 289 2bbl/Cruise-O-Matic - Money pit/project
    Sounds like you have a bulb out. The turn signal flasher uses a type of circuit breaker to blink the lights. If one bulb is burnt out, not enough current will flow, causing the breaker not to open. Check the turn/stop bulbs on the right side. I bet you'll find one burnt out.
      Sweet, glad its only something minor. Ill look into it
        Wait wait wait...the right turn signal on the dash is on all the time?
        One of 3 things.
        --Bad bulb
        --Bad flasher
        --Bad turn signal switch
        Check in that order.
          If the right turn signal is on all the time, the cluster may have a bad ground.
          Sent from Blaster coming at ya from Autobot City.
            Sorry to bump. I put a new bulb in, it was the white light that illuminates when you flip the signal on. I tried it and the signal still did not flash. it works just fine when the driving lights are off, but as soon as i put them on, the right signal arrow on the dash comes on and the signal doesn't work. My dad said it could be a bad flasher so I'm gonna look into that next. Fingers crossed its nothing major
              make sure someone didnt put the wrong bulb in somewhere. They should be dual contact lamps. if someone put in a single contact lamp, it would have shorted the parking light power feed back to the blinker light feed. Check the front and back lights to make sure its not that.
                Ahh, never thought of that. Hmmmm
                  I'll take a look tomorrow before I go to work, pretty sure I bought dual contact bulbs.
                    you changed the front and rear lamps? Just curious because it wasn't clear from what you said. I was just thinking if you changed one, the other may be the wrong kind. Might also be worth looking in the socket itself to make sure the contacts aren't bent into each other or anything like that.
                      nononono. I didnt touch anything but the white turning lamp that illuminates the orange signal light at the bottom of the car. That was the bulb that was out. I'll take a look at the contacts tomorrow. It only happens when I turn on the driving/headlights. when they're off the right turn signal functions normally
                        Question: How the hell do you get the signal housings off these cars?! Ive been trying to figure out why it won't budge even though I've taken out all of the bolts that supposedly go to it.
                          there are 2 or 3 nuts up there in the fender, in the area where like 6 are. you have to get the right ones. if you aren't bleeding, you haven't found the right ones yet
                          there is also a rear turn signal lamp. make sure that one is the correct type as well. comes out from inside the trunk, behind the carpet on the side.
                            I found something new today, when the driving/headlights are on the passenger signal illuminator bulb whatever its called stays on indefinitely, which was the burnt out bulb I replaced..I may have bought the wrong bulb
                              Do your hazards still work?
