could also be a bad ground. I think the headlights and the turn signal/marker light use a common ground wire, which lands somewhere on the inner fender area, sort of near where you put your hand through to change the bulb. Make sure its clean.
Right turn signal issue
Hazards work fine, even with the driving lights on.
Ill take a look at the ground wire and see if its corroded
2011 Ford Ranger Sport 4.0 2wd - Magnaflow Axleback exhaust, K&N 63 Series CAI, DiabloSport 87 Octane tune, LEDs, 3000K LED projector fogs, 5000K Mini H1 projectors - Daily
1967 Ford Galaxie 500 Sedan "C-Code" - 289 2bbl/Cruise-O-Matic - Money pit/project
