86 vic Windshield wiper motor help
    hey i need some help removing my wiper motor if anyone has maybe a diagram or something that would be great. this is for a 1986 crown vic ltd
    sigpic1986 crown victoria ltd 5.0
    Mods- True duals with just cats, msd cap/rotor/coil, ford racing 9mm wires,
    CAI, 180 t-stat, poly sway bar bushings/endlinks, HD shocks, cooper cobra 235/60r15, fresh paint
    On my 91, you just unplug the 2 connectors, unbolt 3 bolts, pull the wiper motor out a little bit and use a flathead screwdriver to disengage the little clip holding the motor to the wiper linkage.
      Ok cool thats what i figured. how much force do you use to detach the motor from the linkage? just a slight twist? i dont want to snap it haha
        The clip is the tricky part. Its got a tang that locks over the post of the motor. You have to lift that up enough to slide the clip over, then the whole thing will just fall off.
        you can't really see it too well in that picture, but the part that folds back on top has a tab that sticks down. Thats the piece you have to lift up so that the clip will slide off. Try to not lose the clip. It likes to go flying, and the replacement motors don't always come with a new one.
          Perfect that is exactly what i was looking for. hopefully i dont lose it when it pops off, thanks
