Anyone heard of/done the Mark VIII Rad fan swap?
yup... lots of threads about that around here. Like I said on the other board, start-up draw is a bitch on the Mark VIII fan. An in-line power cap will help with that or a variable speed fan controller (kinda spendy).
Fuck that fan. Get a dual fan from a 99 v6 contour. Less power draw even on high, and it flows better than the mark viii fan. Had a mark viii fan in my grand marquis, it moved air but every time it turned on the car almost died.
I want to try to swap in a mid 90's areo electric fan, the kind that mounts to the fan shroud for the dual fan setups. I noticed one day that the top center nub bolts to the shroud in a flat spot that looks awfully similar to the weird random flat spot/notch found top center on some box fan shrouds.
One of three almost-correct mounting spots is a huge head start from none when it comes to that sort of thing.
I can't remember if the '90 Townie shroud has the notch though...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 86VickyLX View PostFuck that fan. Get a dual fan from a 99 v6 contour. Less power draw even on high, and it flows better than the mark viii fan. Had a mark viii fan in my grand marquis, it moved air but every time it turned on the car almost died.
Found some interesting info. http://www.thehollisterroadcompany.c...VIIIrelay.html
Sent from my '85 Lincolin Town CarUsing Tapatalk
I wound up harvesting some funky electric plug-in-line contraption that works with a MK8 fan... I wonder if it's some kind of 'soft turn-on' module???Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by kodiak View PostSounds like you have a stock alternator. If you go from a dead stop to high speed it will spike anywhere from 80 to 100 amps.
speaking of this... anyone know where to get the C-clips for the wiring that hold the harnesses together on the cougar/contour/mystique?
