OK so given a wiring diagram I can certainly figure out how to wire something up.
But tracing faults... has never been a strong suit. And for better or worse I've never had the opportunity to practice.
SO the other month several things stop working. My aftermarket radio has one of those automatically hiding faceplates, so a portion of it, the motor to pull it in, receives power even in key-off position. That stopped working. The dome lights and map lights no longer work. And the clock is off.
On the fusebox by the steering column, fuse #8, a 15amp fuse, is blown. I replace it and all is well. The wires at the point of the fuse are green with a yellow stripe.
Well it blew again a few days ago and it's a permanent short, now. Some wire some where is exposed and grounding...
Does someone have a diagram? I can't find my book. May have lost it in the move 2 years ago. 1990 grand marquis.
And any general advice for how to logically approach this problem, well short of taking apart the whole dash and harness?
