I remember back in the day copper heater cores were the best to get. Does that still hold?
Heater Core hoses
the aluminum ones work very well and you shouldn't need to worry about the solder cracking as they're welded.
Gadget, on my '86 I did by-pass the TBLOS, but did not plug the vac lines......do I have to do this, and if I do not, what happens?Originally posted by gadget73 View PostI would vote for installing the non-ATC hoses and eliminating that stupid thermal switch. They're usually bad by now, and if its not i wouldn't expect it to survive being disturbed. Jumper the wires, plug the vacuum lines, forget it was ever there.
if you don't plug them, there's just a vacuum leak and the AC system will drop to heat/floor under load.
I never plugged the lines on my 89, and never had any issues. I guess that portion of the switch still worked.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
