The air conditioning in the '85 Ltd Crown Vic works but doesn't blow cold out of the vents
... The compressor turns on and the hoses and lines get cold under the hood but coming out of the dash there is a problem.
I've tried manually moving the vacuum dashpot in the passenger footwell in and out. I can make it get hotter but not colder. I've tried taking the 1/4 hose off of the drum behind the glovebox with the same results. My car has automatic climate control
Another perhaps unrelated problem is the air doesn't blow very hard, like highest fan speed doesn't work?...
Thanks for your help
