It's a cold one here in Ohio, below zero, I think I was 5 years old the last time it was this cold. I had a hell of a time yesterday getting into my car because the door kept freezing shut and 3 times I had to dump hot water on it to get it open (note to self, grease EVERYTHING when weather gets warmer)
ANYWAYS, I called off work today because my 90 Grand Marquis won't even crank. I turn the key and hear a single err noise. Disappointment. Come on trusty Bison, you're supposed to be reliable.
Shivering Grand Marquis- "f-f-f-fucck you it's COLD"
I turned the key to the on position to hopefully give it some time to build up fuel pressure and even tried turning on the lights for a minute to warm up the battery (I read this online, I don't stand behind it, I just gave it a shot).
I only know of a few possible causes for this. Maybe a bad starter or bad solenoid, but I don't think that would be caused by cold weather. The last few times I've had my battery checked they always say it looks fine but I know it's not a brand new one. I would say that maybe the battery is freezing up but it seems like everything has power. Could it be the alternator? I've been reading up on a 3g swap...
If Canadians can drive through this shit all the time I should at least be able to get into my car and get it started!
Any thoughts or suggestions are appreciate as always, Thanks and stay warm!
