Hey guys, I've upgraded to Hella low and high beams over my HID low beams and stock high beams. I ripped all my HID shit out, but I think my friend who installed the HID's switched the two low beam wires around (red/green, black stays the same I assume). If you're looking at the connection from the drivers seat, which wires should be in which terminal? (I think my green is on the left, red on top, black on right) Or if someone could just take a picture of they're stock passenger side low beam that would great.
I'm also having a very hard time adjusting the headlights themselves. How do you guys with Hella's do it? The rubber boot that goes over the back is a bit bigger than the stock one so they don't sit all the way back in the headlight frame like the stock ones do. Is there any way around this?
Another problem I've come across is since I installed my Hella low beams last night, my brights linger on when I don't have them on. My bright signal on my dash emits a low glow as well as the headlights. I already checked and my headlight tab in the cab isn't turned to far one way or another, it has something to do with installing the low beams.
I'm also planning on installing headlight relays soon. Is this the kind of relay that would work - http://www.delcity.net/store/Normall...tacts/p_791795
Also my spade connectors are not looking very good. Are these the kind that will work - http://www.delcity.net/store/Non!ins...inals/p_802000
