I know a CFI car can be swapped to a 2bbl carb. Not gonna lie I've thought about both a 4bbl swap and 2 bbl swap. I know a 2bbl would be easiest. I'm not saying I'm going to do a swap but I simply have questions.
Is there any advantage at all to swapping to a carb? If so, would anything be gained by going to 4bbl over 2bbl? What are the disadvantages other than tuning?
Fuel economy isn't a huge issue and I know if I did ever swap, 2bbl may be more fuel efficient over a 4bbl.
Also, would it be worth it on a lopo? Other than hurting the wallet, would it hurt to try out a carb?
Like I said, not looking to do a swap. Just curious only because I've seen many swap to EFI and I had an '86 CV with EFI and an '88 M7 H.O.
I've also been tossing around the idea of EFI too but not looking to swap. Thanks.
