OK, my alternator went out tonight... (Bearings, go figure!) I have two lifetime guarantee alternators from Advance Auto parts, so I can swap one if the alternator goes out, then take it back for a new one, and put the new one in the trunk for a spare... So I get out my brand new rebuilt alternator that I keep for an extra... and the last time I swapped it out, Advance gave me the wrong fricken alternator... it is at the 3:00 position, and I need it at 9:00... How hard is it to re-clock the alternator? Of course my local store doesn't have one, but they can get it for me tomorrow morning at 10:00 AM... (They don't know it yet, but they are bringing out the new ones to me at the Firehouse, where my car is presently torn down... Since this is THEIR screw up!) I watched a guy do it once at the alternator shop, but that was a long time ago, and I wasn't really paying attention... I THINK it is just a matter of taking out the four case screws, and turning the housing to the correct position, and putting the screws back in, right? And as long as you don't lift the case, (Separating the two halves) it should work, right? Thanks for any help....
"Reclocking" 100 amp alternator...
http://www.tomspolicecars.com/Tags: None
Not particularly hard.
This shows how to rebuild it, but all you really need is the dissassemble and re-assemble parts of it. Just rotate the back case to the positon needed and bolt it up. You'll need a nail or similar sort of thing to hold the brushes in position for re-assembly.86 Lincoln Town Car (Galactica).
Good read, but didn't really answer my question if you can take the four bolts out, and just turn the back of the case... To re-clock it... Oh well, stuck at the Firehouse tonight until Advance delivers my new one in the morning... I figured if I could turn the case to the right clock position, I could do that, and install it on the car... and go home!
Decided to re-install the old alternator, just didn't tighten the belt as tight, so it would take the strain off of the bearing that is going bad... and drive home tonight... and to advance in the morning... And change it out in the parking lot real quick... I can change one in about 20 minutes... no problem!!
Originally posted by trwp72 View PostGood read, but didn't really answer my question if you can take the four bolts out, and just turn the back of the case... To re-clock it... Oh well, stuck at the Firehouse tonight until Advance delivers my new one in the morning... I figured if I could turn the case to the right clock position, I could do that, and install it on the car... and go home!
you may not need to jack with the brushes if you don't completely separate the case. Just get it enough to rotate and then lock back together where needed. Shouldn't even need to take the pulley off. This is the way I did one of the 3G swaps I dealt with (reclocking the 3G).
Originally posted by sly View Postyou may not need to jack with the brushes if you don't completely separate the case. Just get it enough to rotate and then lock back together where needed. Shouldn't even need to take the pulley off. This is the way I did one of the 3G swaps I dealt with (reclocking the 3G).
Well, I finnally put the old one back on the car, and limped it down to the auto parts store... it ended up locking up completely when I shut the car off! So I got the replacement for the one that was wrong, and another one for the one that was bad... For free... So I got the new one installed, and the extra one back on the trunk, and they are both the correct one this time!!! Thanks for all of the comments.. if I can find a 100 amp one in the junk yard for cheap, (I have a friend that owns a junk yard) I may buy it just to experiment with, and see what it takes to re-clock one, just in case anyone needs to do it....
I have a 60A 1G sitting in my garage. Is the 100A physically different? I can experiment on mine as I'll probably never use that one again.
The 100 amp is bigger, but I don't know much beyond that. I think its basically the same method of assembly, just with a smaller case.
yes, you unbolt the rear case, rotate as needed, and re-assemble. That article is the complete teardown, but a simple re-clock is just the 4 bolts and something to hold the brushes in place. I did it on my Mark VII which uses that same alternator. It was installed already when I got it, but clocked in a stupid way that made the wiring not sit right.86 Lincoln Town Car (Galactica).
