So my cruise works but not like it should.... When I set it I have to hold the on button in and push the coast button over and over and then it catches and holds perfect. If I hit the set accel button it climbs continually ans the resume done work.... Any ideas... I'll live with it for now unless it's something simple...
Weird acting cruise control on my 86 TC
I'd also remove the steering wheel and clean up the slip rings under it. The buttons connect through what amounts to 3 small motor brushes running on a copper contact ring. If that gets gunked up, things don't act right. Wipe the contacts off with rubbing alcohol and polish them with really fine sandpaper (1000 or finer) or a piece of heavy paper. Don't take much off, just shine them up.86 Lincoln Town Car (Galactica).
