I've got a small problem with the GM. First off, she starts up no problem wether its hot or cold. The problem I'm having is that when accelerating, wether it be from a stop or while rolling at speed, it seems to bog when the gas is pressed halfway or more. If I take off from a stop easily or just accelerate around a corner or a slight hill it's fine. But if I floor it from a stop or to downshift to 2nd or 1st it bogs.
The vacuum lines look ok and fuel flow seems ok. I put in a new fuel filter back in July. No problems starting up at all. She did stall on me twice yesterday and tonight once, as I pulled into the gas station. And after both instances yesterday she fired up no problem as well as tonight after I put gas in her. Is any of this choke related?
