check the low pressure switch connections. If there's refrigerant oil (green looking oil) on the terminals, replace that sensor - it's leaking. If not, get some dielectric grease and put some on the terminals when you put them back together. Same with the relay. Check the terminals for crud (even though you just plugged in a new one) and maybe even clean out the relay harness. If the wires going to the relay are loosing insulation the contacts may be to blame (resistive and making heat). Clean them and put some dielectric grease on them too.
also, sometimes new parts die... so it may have just been a bad relay.
